07-29-2023 03:07 PM
I have a total of 4 hardwired cameras on my system. Just so happens the 2 cameras that just happen to die were purchased as a 2-pack. Both sets of cameras were purchased exactly one month apart in November 2021 & December 2021
The other 2 cameras are working and had no issues with them. Also, All the cameras are on surge protectors.
We had no power outage. I've checked the outlets that they are on and confirmed there is power to the outlet.
I also went ahead and disconnected the power cable and plugged the USB into my laptop to see if a status light would appear and I even swapped out the cables from the USB from another working camera and It still no status light.
Have I run out of options?
07-29-2023 03:32 PM
The older Google Nest Outdoor Cameras (we have three) do not have a reset button, so the only way you can do a factory reset is to remove them from the Google Nest app by going to Settings | Remove device | Confirm, provided that you can still see the cameras in the Google Nest app. If you are able to do that, you could then try reinstalling them.
Otherwise, you could try contacting Support using the link and instructions in the post below, to see if they have any other suggestions:
08-02-2023 06:03 PM
Hi JoeyD,
I'm jumping in to ensure everything is good here. Have you seen MplsCustomer’s last response? Let me know if that helps.
Lance
08-09-2023 06:09 PM
Hello JoeyD,
I wanted to follow up and see if you are still in need of any help. Have you had the chance to try the suggestion above? If yes, how is it?
Lance
