10-11-2025 11:31 AM
I have a nest outdoor wired cam that I view from the webview home.nest.com using the picture in picture feature where I can detach the camera view into a separate window.
I have Luma security camera program that has 8 camera views in a 9 view grid - I fit the nest cam detached window in the 9th vacant spot. Works perfectly. Well... almost...
The detached window plays fine but that window randomly and constantly keeps expanding from its original size. If I put it in a corner of my PC screen, it will keep expanding until it eventually covers most of the screen and other camera views.
Any way I can fix this annoyance?
It's also unfortunate that if you have more than one camera on the home.nest.com page - you can only detach ONE camera with the picture in picture feature at a time. I have to use 4 different browsers to get 4 detached picture in picture windows.
10-14-2025 04:12 PM
Hi pikpen,
Thank you for reaching out to the community. I see you're having trouble with the Picture-in-Picture view for your Nest Camera Outdoor Wired on the home.nest.com page, as it keeps expanding unexpectedly. Additionally, only be able to view one camera at a time out of your ten-camera set up. I understand how frustrating this must be. Let's work together to find a solution.
For better assistance, please respond to the following questions:
Please keep me posted on your findings.
Byron
