Nest cam 2nd gen noise problem
Gavila
I recently set up a nest cam brand new out of the box to use in a nursery. However  the white noise in the background makes it impossible to use. If anyone could help that would be great because without the audio feature it makes the cam pointless.
EmptyNester
Gold Product Expert
Gold Product Expert
Hi, I'm an end user like you.  Some natural 'room tone' sound is normal but it sounds like you are hearing something above normal.  Just as a test can you move it to another room in the house and see if it sounds just as bad?
janthadeus
Checking in — I just wanted to make sure if you've seen EmptyNester and Dianahemes’s response. Let me know if you have more questions in mind.
I appreciate the help here, EmptyNester and Dianahemes.
janthadeus
Hey Gavila,
It's me again. I want to check if you still need help. Don't hesitate to reach back if you do.
janthadeus
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
