05-31-2024 08:37 PM
I wanted to put the anti theft chains with my nest cam. Ordered something from Amazon, but they gave a different screw. Was wondering if anyone knows these screw size which we use at the bottom of the cam?
06-03-2024 10:29 PM
Hi @CaptainT,
Thanks for reaching out about your Nest Cam Battery.
While the Nest Cam Battery is a great device, it's important to know that it's not official information about screw size.
About Nest Cam Battery:
We have this information that is What you'll need for installation:
On the technical specs we have What is on the box:
As a last resource you can check documents included with you Nest Cam
I hope this information could help you solve your question.
Brandon.
