Nest cam outdoor Power lead replacement
Muddafunksta
Hi ,
My Nest Cam outdoor power lead is faulty.  I have tested with another power lead and the camera works correctly.
I have also tried replacing the fuse and trying in a different power socket, this has not worked.
How can i replace the cable?
Muddafunksta
Any comment? Need help as camera does not work.
Thank you for your patience. If you are seeking a replacement, please first fill out this form so we can collect some important information from you. Once the form is submitted, you will have your case number. Please be aware that this thread will be locked.
