Nest cam with floodlight brightness
Mario714
If I set my nest cam with floodlight brightness to 25% one night, and have a routine for sunset to sunrise.  Will the floodlight brightness stay at the same level when the routine turns on the light the next night?
6 REPLIES 6
Cathal_S
Hi Mario714,
I don't own the floodlight camera myself so I don't know if the brightness will change but if you are using a routine you could add an action that will adjust the brightness within the routine.
Cathal
I tried looking for that option, but the only action I see is to turn light on or off, no brightness
Mk78
Hi @Mario714 , I noticed in general for the lights, that if you adjust the brightness, it keeps the same settings and doesn't automatically resets.
So you should be ok, and keep the 25% the next night.
So
Mario714
Thanks, yes I can confirm that your right, next night stayed at 25%, actually brought it down to 1%, light is really bright.  At 100% I was lighting up the while street, lol
Just checking in to see how the conversation is going as there's been a lapse in activity on this thread. Thank you @Cathal_S for all of your help!
Best regard,
Mario714
Yes I found my answer thanks
