01-02-2024 07:44 PM
Camera and light have been working fine for months. But for one week, the floodlight has not worked. The camera works fine and still records motion, but the light does not come on and I can’t manually turn it on either. What is causing this? How can I fix it?
01-06-2024 02:19 PM
Hello Ashley11
Thanks for reaching out here in the Community. Try checking the wires if there are damages. You can manually turn the floodlights on and off.
To turn on or off the floodlights manually:
1. Open your Google Home app.
2. Select your Nest Cam with floodlights.
3. Go to settings> Floodlights> What turns on the floodlight> Live viewing.
Let us know how it goes.
