05-26-2024 09:19 AM
I have just bought nest cam with floodlight, trying to install using online install guide but mt cam did not come with grounding wire and the mounting plate is different to that shown in video.
i dont have a junction box fitted where I intend to install light and was going to fit one but it looks to me that the mounting plate supplied will suffice if I run a cable to it, but where can I fit the earth wire from the cable as there are no grounding points in mount?
05-26-2024 11:28 AM
You can try contacting Support:
