11-10-2023 12:56 PM
My camera has not power. But my lights turn on when I flip the breaker, I can charge my camera and it will turn on but no power the wire
11-10-2023 12:57 PM
Is it the cord or something hooked up wrong
11-10-2023 03:13 PM
With the floodlight camera, if there is a switch on the camera's electrical circuit, the switch should be on at all times, though Google Nest never seems to state that explicitly anywhere. The camera is designed to be receiving household current at all times.
Are you certain that the floodlight fixture is wired correctly?
What do you mean by "no power the wire"?
11-15-2023 12:54 PM
@MplsCustomer The cord that comes from the fixture to the actual camera. The camera has no power but the light does
11-15-2023 02:31 PM
Hello everyone,
@Stin84, thanks for reaching out here in the Community. To know more about this issue, I’d like to confirm, is this newly installed? Is there any damage to the gold pins on the charger from the floodlight? Who installed it? Try checking if there's any damage on the charger cable from the floodlight.
11-15-2023 04:35 PM
I'm still confused. You said you can charge your camera and the camera will turn on, both of which require that the camera is receiving electrical power, so what do you mean "no power the wire"?
Are these installation instructions of any help?
https://support.google.com/googlenest/answer/11003780
11-18-2023 02:24 PM
@MplsCustomer, thank you for your efforts to help and your input about this.
@Stin84, in case you have additional questions, feel free to respond to this thread anytime.
