Nest camera with flood lights
Sorinel
can someone tell me if there is a way to disable the flood light coming on ? I do not want to have those coming on as I have slips hue outside my driveway. Please let me know.
BG
Sure... Open the Home App. Click on the Camera icon. Pick the camera that you want to change. Then, tap on the Settings icon (the cog at the top right on android) > Floodlight > What turns on the floodlight. Then, you can turn off or on the different types of activation (Motion, Live Viewing, Camera Events)
Hey there, Sorinel.
I am glad to hear that you chose to get the Nest Cam with Floodlight (wired)! I hope you are enjoying it so far. In the case of disabling the Floodlight, just as @BG stated, you can follow those steps to achieve this. I also have another great article that goes over changing settings for the Nest Floodlight if you have other needs. You can find the link to the article here. Please let me know if you need further assistance!
Hey folks.
