Nest doorbell Wired
Matt123
I really don't know what to do next!
I'm having issues with my nest wired doorbell constantly going offline. It connects for a bit then disconnects and reconnects every 20 mins or so.
I have done multiple factory resets, deleted my home and set up a new one (multiple times), switched off all other devices, tried a new power supply, bought a new mesh router (was using virgin hub 3), assigned a static IP, switched off the firewall, turned off the mesh roaming for the doorbell, turned off optimisation. The doorbell is now inside my house, connected to a new power supply and is physically sat on top of the router and it's still going offline.
Is there something else I can try?
@Matt123
Which doorbell do you have? Your post says you have a "Nest Doorbell (wired Gen 2)", which is installed in the Google Home app, but your post also says "Nest app (Android)".
How old is your doorbell and is this a recent development?
Have you tried contacting Support about a warranty replacement?
