09-13-2021 11:03 AM
considering the nest doorbell battery and wanted to know how it can be charged? Does it have interchangeable batteries so can plug in a charged battery and place drained one on charge so ready to swap when needed.
I cannot seem to find this info online. Bit pointless if I have to charge the whole unit which means having to lose the doorbell and motion notifications while it’s charging.
thanks
09-16-2021 02:30 AM
It does NOT have a removable battery, you have to remove the camera from it's mount with the provided tool and charge it
09-16-2021 02:44 AM
Thanks for confirming. Definitely won’t be buying this if the whole unit has to be removed and charged for 5 hours.
