06-25-2022 04:18 PM
My nest doorbell camera was already wired and installed but I changed the password to my wifi which caused me to do a factory reset on it (which is an entirely other ordeal). When I finally got the device reconnected to the app and network, I chose that the device was wired and already installed to avoid going through installation steps again but when I go back into the app, it saying that it's not wired therefore my indoor chime won't work anymore and I'm not sure how to change it to make sure it shows wired without having to go through the frustrating process of a factory reset again.
06-25-2022 07:55 PM
Do you have the original Nest HELLO doorbell or the new Nest Doorbell (Battery)?
You might try removing the power from the doorbell for about 30 seconds and reconnecting it and see if the problem goes away. I seem to remember it should auto-recognize the wired mode... but I might be wrong on that.
Hmmmm, I think your best option is to get Google tech to help you via phone or chat. Here is the link:
06-28-2022 03:54 PM
Hey Courtgilmore,
Appreciate the help, EmptyNester. I'm dropping by to ensure if everything is covered here. Hope that sheds some light on the issue.
Archie
07-01-2022 07:42 PM
Hey Courtgilmore,
I wanted to follow up and see if you are still in need of any help? Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
Archie
07-03-2022 05:03 PM
I will give what they suggested a try. Thank you!
07-05-2022 10:10 PM
It's me again. Just checking in to see if the troubleshooting steps shared helped. If you have other questions and concerns, feel free to let me know.
Steve
07-11-2022 03:17 PM
We haven't heard any updates from you. Please let us know if you still need help as we will be locking this in 24 hours if we won't hear back from you again. Feel free to start a new thread and we'll be happy to help.
Steve
07-03-2022 05:00 PM
I have the new nest doorbell (battery). I'll try that and talk with Google tech if the issue continues. Thank you!
07-02-2022 09:36 PM
Steve
07-03-2022 05:02 PM
I haven't gotten a chance to try the solution EmptyNester suggested but I'll try turning off the power or reach out to Google tech. Thank you!
