a month ago
Had this Doorbell cam for over a year but lost connection over a week ago. I have tried restarting many times and resorted to factory reset as it did not work.
However holding the pin in for 10 second (20 or 30) does nothing. The white light turns on after about 2 seconds then stays on, nothing else.
I’ve tried using different pins, tried many times and I feel the button depress inside the pinhole.
Please advise
a month ago
Hi @Dcoy,
It sounds like the factory reset process on your doorbell cam might not be working as expected. Here are a few things you can try to troubleshoot the issue:
Double-check the reset method:
Ensure proper pinhole access:
Extended hold:
Power cycle:
Contact Support:
Here are some additional things to keep in mind:
By following these steps, you should hopefully be able to factory reset your doorbell cam and regain connection.
Mario.
a month ago
Hi @Dcoy,
Extended hold:
Power cycle:
Contact Support:
Mario.
a month ago
My Nest Doorbell (battery) has stopped working for no reason recently. Even after charging it a entire night it doesn’t turn on. I have tried the factory reset but I never get to the countdown or yellow light even after pressing the reset button for a long time (30sec +). I get a solid white circle and green light on but no response and I am unable to connect it to the wifi.
Could you please advise how to proceed?
Thanks
Ed
a month ago
Are you using an unfolded paper clip to ensure the reset pin is actually getting depressed for at least 12 seconds?
a month ago
Yes, the normal reset seems to work (I get the small white light on) but it never gets past this (i.e. to the factory reset) and doesn’t solve the issue.
a month ago
Mine did exactly the same last week, I tried everything I could but unfortunately I couldn’t get it working again. I ended up buying a new door bell.
a month ago
We don't have a battery doorbell (and are sticking with our 3 Nest Hellos), but judging from posts in this forum, it seems the battery doorbell has problems.
