a month ago
I have many Nest Cam devices and am very familiar with the correct settings. I have two Nest Cam wired doorbells and the audio on one works perfectly and then other one is almost non-existent. The level is so low that I cannot hear sound from it even when a lawnmower is 10 feet away from it.
I have checked all the settings and they are all correct and it is still not functioning properly.
I have done both soft and hard resets and still it is not working.
I suspect that the device may need to be replaced.
Any assistance?
4 weeks ago
Hi mike175gr,
Thanks for reaching out to the community! I understand the microphone on one of your two Nest Doorbells (wired) is barely picking up any sound, even though the settings are correct and you've already tried both a soft and hard reset. I'm here to help!
To isolate the root cause of this issue, I have some questions for you:
Juan
3 weeks ago
- last edited
3 weeks ago
by
JuanCH
1: The model info is as follows:
Nest Doorbell (wired)
Serial no.
Software 4110055
2: It has always been very quiet since it was installed. The microphone never really worked well.
3: No, the unit was never dropped or damaged. It was taken out of the box and installed on the wall.
4: No, it is installed out of direct sunlight and on a covered porch.
Thank you for your engagement and I look forward to resolution!
3 weeks ago
Hi mike175gr,
Thanks for getting back to me! The team would like to learn more about this behavior. When you get a chance, please fill out this form and let us know when you're finished. We'll have someone reach out to you via email from there.
Sincerely,
Juan
3 weeks ago
I filled out the form with the needed info. Looking forward to your feedback and resolution.
3 weeks ago
Hi mike175gr,
Thanks for the update! I'd like to suggest checking your email, as our dedicated team will be reaching out to you there.
Feel free to post any further questions in this forum.
Juan
