Nest doorbell offline due to battery issue.
Natalielynnn
Hi
I’ve had my doorbell for 5 months
& recently it just went offline randomly with like 60% charge left. It says contact google support. So I removed it from my home app & did a factory reset. Factory reset went as it should.. with the noises and beeps or whatever. But plugged in to the outlet it remains at 80% charge w a solid yellow light. Also my home app can’t find it to pair. What the hell does that mean.
thabks
6 REPLIES 6
@Natalielynnn
A solid yellow light is supposed to mean "Factory reset has started":
https://support.google.com/googlenest/answer/9268073?hl=en#zippy=%2Cgoogle-nest-doorbell-battery
That’s what it’s supposed to mean lol…. I factory reset it two days ago and it’s been sitting on charge not moving from 80% with a solid yellow light
@Natalielynnn
I'm just another Google Nest customer, and we don't have a battery doorbell since we live in Minnesota and it really can't function at temperatures below freezing (https://support.google.com/googlenest/answer/11830989).
But if we had one, I would be tempted to try another factory reset by pressing the reset pin/button for at least 12 seconds (https://support.google.com/googlenest/answer/9252162?hl=en#zippy=%2Cnest-doorbell-battery), unless you have already tried that.
Unfortunately, nothing in Google Nest's instructions say anything about whether it's good or bad to do a factory resets while the doorbell is plugged in for charging. You could try a factory reset when it is NOT being charged.
Checking in — I just wanted to make sure if you’ve seen MplsCustomer’s reply. Let me know if you need more help.
janthadeus
Hi Natalielynnn,
Thanks for chiming in, Jake.
