03-15-2022 06:08 AM
My Nest hello went offline with 49% battery.
internet connection is good as all the other nest/ google products working fine. When I pressed the ring button it made an audible sound on the hello unit but wouldn’t connect to the internet to give alerts to hub/ iPhone. I proceeded to charge the hello to see if this helps but now no light comes on unit and the hello is unresponsive, I tried to master reset but this didn’t work either. Unit is dead and doesn’t respond to charging etc.
can I please return the unit under warranty as it was purchased from the google store in August 21.
I be will have to buy a replacement unit as it doesn’t seem like an easy process to get a replacement through the google store
kind regards,
Michael Atkinson
03-15-2022 08:39 AM
Thank you for your patience. If you are seeking a replacement, please first fill out this form so we can collect some important information from you. Once the form is submitted, you will have your case number. Please be aware that this thread will be locked.
