02-06-2023 05:54 AM
Issue : Nest hub Camera goes offline after a hard power cycle or scheduled reboots post automatic updates. No permanent Fix
Temporary fix: remove the nest hub max from the Google home and its room association , you will then still find the device discovered but not associated with anyroom, add it back scan the qr code and resetup the nest came using the setup nest came icon on the Google home app
While this temp solution works it's frustrating having to do it everytime the device reboots.
03-12-2023 06:07 PM
Hi TechnialKhufu,
This is not the experience we wanted you to have, let me help you. A few things: when did your issue begin? Were there recent changes after the update? What was the update about?
It would help a lot if you could do a sequential reboot first:
Keep us posted.
Dan
03-15-2023 06:15 PM
Dan
03-16-2023 08:19 PM
Just checking in to make sure that you saw our responses. I'll be locking this thread if we don't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Juni
03-18-2023 10:03 AM
I still see the issue all of the instructions provided were done multiple times there.is.stil no permanent Fix. Looking forward to hearing from you
System firmware version: 9.20221010.3.176
Cast firmware: 1.67.330920
Language: en-US
