02-06-2022 04:36 PM
I recently installed and mounted my nest battery doorbell and do not see it on my nest app. It works fine from my Google home app. Is there any way to set it up on the nest app? The only option is for a wired nest doorbell which I used to have. I have other nest products that work fine. I also pay for nest aware.
02-06-2022 05:58 PM
Nest Doorbell (battery) will only work on Google Home app.
02-06-2022 06:06 PM
When we bought a Google Nest Camera (Battery), we discovered that the Google Nest cameras and doorbells introduced starting in the fall of 2021 work ONLY with the Google Home app and NOT with the Google Nest app or the home.nest.com website. Google Nest's explanation for this can be found below, along with customer reactions.
Your battery doorbell should, however, work with your Nest Aware subscription. But the battery doorbell only records events (even when wired); it cannot record 24/7.
02-15-2022 11:29 AM
02-22-2022 11:44 AM
02-23-2022 11:57 AM
Hey Folks.
