Next camera not connecting
Ash2
My google home was was working fine until I added the battery doorbell.
it took forever to get the door bell to work but since the the camera on the hub no longer works
i can’t stress how extremely disappointing this is as you’d expect it to be seemed seen as it’s one brand
move tried the suggestions that I’ve found and none of them have worked so far,
any help would be much Appreciated
thanks
Ash
Azarco
Hi Ash2,
If you're still having trouble with your Google Home, please give these steps a try:
  1. Reboot your speaker
  2. Reboot your router
  3. Make sure your devices are within 15-20 feet of your router.
  4. Factory Reset your Google Home
If the issue persists, feel free to submit another post and provide as many details as possible so that others can lend a hand. Hope this helps!
Alex
