11-10-2021 11:41 AM
I changed routers and was having difficulty connecting to new wifi. After doing factory reset, I get solid white light but does not turn to blue to start the connection process.
Solved! Go to Solution.
11-15-2021 03:41 PM
Ok so I figured this out. When you press the reset button (with paper clip etc) hold it for at least 30 seconds or until after you see the yellow light and they go off. Then remove the paper clip and the light will turn blue.
11-11-2021 01:41 AM
Exact same problem does anybody know what to do???? Is there a way to get this thing refunded?! It has been nothing but issues 😕
11-15-2021 03:19 PM
If you find a solution outside of this forum, please post it here. I am SOOOO frustrated!
11-15-2021 01:21 PM
I am experiencing the exact same issue. I'm trying to reinstall the doorbell, but now the white light is solid and the blue light is not turning on. I've already done a factory reset on the doorbell as well. Not sure what to do next.
11-15-2021 03:20 PM
If you find a solution outside of this forum, please post it here, thanks
11-15-2021 03:41 PM
11-16-2021 06:19 AM
This worked!! Thank you so much!! I had tried that reset button but only pressed for 5-10 seconds initially since the darn instructions stated 5 seconds was sufficient. Held it for as long as possible until the yellow light came on and it took roughly 25 seconds for me. Lol. This really could have been avoided if the manual was accurate.
Anyway, thank you again!!
11-16-2021 02:58 PM
Garrett DS
12-10-2021 01:02 PM
Just fix the insructions for reset. I spent about 3 hours with this same issue until I came accross this post. Thank you POGO!
12-12-2021 08:29 AM
Glad it worked for you. Yup instructions not very good!
12-13-2021 12:48 PM
12-21-2021 02:32 PM
Hey Folks.
