No push notification sound on iphone
Kilomike911
Hello. Installed doorbell (battery) yesterday.  I’m receiving notifications on my phone but only silently. There’s no sound notification at all.  I’ve checked the app settings. Sound is on.  iPhone settings indicate sound is on. Volume is up. Nothing.
11 REPLIES 11
Rubes
Have you checked the notifications settings on the iPhone itself? Settings > Notifications and under Notification Style, check to see what settings are on or off.
Yes.  All setting are ON.
Thanks for your help, @Rubes!
Kilomike911
Yes please. I’m still experiencing the issue
Restarting and factory resetting your Google Nest camera or doorbell will have different results:
Restart: Keeps all your settings, and it should reconnect to the same Wi-Fi network. This is helpful if it ever becomes frozen, has trouble reconnecting to the internet, or isn't working normally.
Factory reset: Erases all your settings and options, and restores its factory default settings. It will not automatically reconnect to Wi-Fi and you'll need to set it up again.
You can find this information, plus additional information on this process here. Please let me know if you have further questions.
SteveT1
I appreciate the help @Brad. I wanted to check back in to see if you have other questions and concerns. Feel free to let me know.
Steve
Kilomike911
Resetting changed nothing. Still no sound on iPhone
What are you notification settings for the Nest/Google Home App on your phone? I would check those and see if you are accepting notifications from this device
Kilomike911
All notifications are turned on. Phone volume is on and turned up.
The notification is delivered, just silently.
This is incorrect.
That would defeats the entire purpose of it being a DOOR BELL.  If I’m not staring at my phone when the notification comes in how am I to know someone is there?
This is absurd.
Also, not accurate as the notification sound plays on my husbands android phone and on our ipad.
It’s an issue with the iPhone only.
