Old owner deceased - how to reset nest cam
Horses1234
I have the nest indoor wired generation 1 - doesn’t seem to have a reset button. The previous owner is deceased and cannot remove from the account. Support told me to unplug for 48 hrs but has not seemed to work - are there any other suggestions to get this onto my account?
RXShorty
Hi @Horses1234
According to the support page there is a reset button.
  1. Locate the reset hole on the bottom of the camera head. It’s between the power cord and the camera neck.
  2. Insert a paper clip, thumbtack or similar into the hole. Press and hold down.
    • At 10 seconds, the status light will blink yellow four times, and you’ll hear a countdown tone.
    • At 12 seconds, the status light will be solid yellow. When the camera begins resetting, you’ll hear a confirmation tone.
  3. Release the button. Your camera will restore to its factory settings.
  4. After the factory reset, your camera will appear as “Offline” in the app until you remove it.
Unfortunately, those are the instructions for the newer 2nd gen Nest Cam Indoor, not for the 1st gen camera.
"There is no factory reset button on Nest Cam Indoor, Nest Cam Outdoor, or Dropcam. To reset one of these cameras, simply remove it from your account." That's the Catch-22 dilemma this customer is caught in.
https://support.google.com/googlenest/answer/9252162?hl=en#zippy=%2Cnest-cam-indoor-wired%2Cnest-cam...
janthadeus
Horses1234, checking in — have you tried the suggested steps shared by RXShorty? If so, how did it go? Let me know if you need more help.
I appreciate the help here, RXShorty and MplsCustomer!
Juni
I just wanted to follow up to see if you still need our help. Please let us know, as we would be happy to answer any questions you may have.
Juni
janthadeus
Hey Horses1234,
Thanks for chiming in, Juni!
