Orbi mesh network - Cam and Doorbell failing to set up
jhsk
Hi all
I have 3 x Nest items: two Nest Cam Wired (2nd Gen) and one Nest Doorbell Battery.
They were connected to my home wifi and working fine.
I performed a factory reset on my mesh wifi setup (Orbi). I re-named the network as it was before, and used the same password as before.
I am trying to re-establish the connection with my Nest items. I have disabled 5G on the wifi network.
However, the items are consistently failing to connect. Typically, the error message is asking me to connect to the same wifi network.
I have removed all the devices from my Home, in Google Home and in the Nest App, so I am essentially starting from scratch.
Can anyone give me a steer, please? I simply don't know what the problem is, and I thought that starting from scratch would work.
Thanks
Jim
