02-28-2022 08:03 AM
My camera is wet on the inside. Don’t know if it is rain or condensation or something else.
It has just gone out of 2 year warranty.
Phoned for help but only got:
1 don’t use it
2 out of warranty so not interested
3 no advice on how to dry it out
I bought this as a premier (expensive) product and frankly I expected more than 2 years from it.
Any experience on drying cameras out or compensation to get a replacement?
Thanks
03-07-2022 11:32 AM
03-09-2022 09:48 AM
I just encountered the same thing on one of my outdoor cameras. It's under a soffit and everything, so not sure how water got into it. It makes the display blurry. How can this be dried out? It was purchased in Feb 2019 so also over two years old. Does that mean the only way to fix is to replace??
03-16-2022 09:14 AM
Thank you for your patience. If you are seeking a replacement, please first fill out this form so we can collect some important information from you. Once the form is submitted, you will have your case number. Please be aware that this thread will be locked.
