12-21-2021 03:14 AM
I have a nest outdoor camera and it’s connected to a switch inside the house. Anytime someone flips the switch off the camera goes offline but when you turn the switch back on it doesn’t power back up.
The only way to power it back up is to unbolt the camera housing, disconnect the power wires and reconnect.
Am thinking that maybe the switch doesn’t cut all the power or is there something else I need to do to repower? It is an older switch and I’m leaning towards replacing that
03-11-2022 10:36 AM
04-20-2022 10:19 PM
Hey PScobee,
We hope you were able to get the help you need but if you're still having trouble, I'd suggest using the power cable and adapter came with it. Check out this link for more information. If the issue persists, feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
Archie
