Power adapter for outdoor camera gen 2 with barrel connector for direct connection to camera
SVOLK1
Does anyone know why there isn't a power adapter available for the Google Nest Outdoor Wired Gen 2 camera that would allow direct connection of the camera using the barrel adapter thus eliminating the long cable?  The length might be nice in certain instances, but when you mount a camera right next to a power outlet, that 18 feet of cabling is annoying and not necessary.  Seems like such a simple fix to allow customers the option of a long cable or a short connection while maintaining weather resistance in all situations.
kcruzgonzalez
Hello @SVOLK1,
Thank you for posting on the community and for sharing your valuable comments regarding the length of the wired power cable for the Nest Cam (Outdoor or Indoor, Battery) and for suggesting a shorter adapter option. Your feedback on the installation experience is truly appreciated, as it helps us identify areas for improvement in future product designs.
Since there is currently no official Google hardware solution for a shorter cable, I strongly advise against attempting to shorten or modify the existing cable yourself. The cable is integral to the camera's weatherproofing and power delivery, and any modification could unintentionally damage the camera or compromise its water resistance, which could potentially affect your warranty.
To ensure your request for a shorter, direct-connect power solution gets the visibility it deserves, please submit your comments directly through the Send feedback option in the Google Home app. This is the most direct way for your suggestion to reach the teams responsible for product development and accessories.
We appreciate you being an engaged member of the Nest community and helping us make our products better.
Kevin
