08-04-2023 03:41 PM
would it be possible to use the Solar Panel from my Wansview B4 camera:
https://www.amazon.de/dp/B0B8ZF1J9P?ref=ppx_yo2ov_dt_b_product_details&th=1
to power my Nest Outdoor Cam by using an USB C Adapter to connect it to the USB of the NEst Cam cable?
https://www.amazon.de/dp/B07Z66MK6L?ref_=cm_sw_r_ud_dp_QE0S52HVQDRTQ00SSPB0_1&th=1
08-08-2023 01:00 PM
Hi broman,
Thanks for posting in our Community. While we don’t have information on whether the solar panel from your Wansview B4 camera can power the Nest Cam (battery) using a USB-C adapter, you can connect it to a power outlet using the included USB cable. This will power the camera, so it doesn't need to use the battery.
More information here: Save battery for Nest cameras and doorbells.
Reach out if you have any questions.
Lance
08-11-2023 11:34 PM
Hello everyone,
@broman, I'm dropping by to ensure that everything is covered here. How's it going with your Nest Camera? Were you able to read the information and check the link that Lance has shared? In case you have an update, you know where to find us.
I appreciate the help, Lance.
