Problem connecting to cloud
MTibb
I am trying to RE-connect my nest doorbell (battery), it was going and then kept going offline.  I have since rectified that by purchasing Nest Wifi (Tripple Pack) and have since had problems trying to reconnect the doorbell.
Error Message: Problem connecting to cloud.
Set Up a device
New Device
Choose a Home
Select Doorbell (Battery)
Scan QR Code
Agree to terms etc ...
Plug in the doorbell
Preparing your device
Error Message: Cant connect to assisting device. RETRY
I of course have done several things factory reset the doorbell, charged the doorbell.  Plugged and Unplugged the Nest Hub Max etc, deleted and re-installed the Home App, tried to add another network in the Home App.  Ensured my Nest Aware subscription is valid.
What am I missing here!!!
JKostal
I'm having exactly the same issue!! So frustrated.
GarrettDS
Have a great day.
Garrett DS
MTibb
Thank you for your response.  My endless patience finally ran its course.  I just took it back to the shop to ask for a refund two days ago.  I mean, I tried and I tried all sorts of ways to get it to work or connect but it simply would not.  A real shame because my area is known for very weak internet and this could have worked a rest if it did what it said it was supposed to do.  Really disappointed with the lack of response from ANY Google tech.
Hey Folks.
