Ready to give up on Nest camera
LenA
I have 5 nest cameras. They constantly disconnect and I have to go crazy turning them off then back on within the app, and with the plug. I recently hooked up my 5th one and its just not staying connected to the internet. I messed with it for an hour, reconnecting multiple times to my wifi, finally had it working. Came inside- not working and wont work. I’ve tried unplugging and waiting a few minutes, plugged it back in- nothing. Same with the on/off toggle within the app.
Anyone find solutions to the same issues?
S3bryan
I know it’s probably not the answer you are wanting but from your post it sounds like your wifi to the camera’s is weak.  Are you using a single wifi router or a mesh type network.  If you are using just 1 wifi router start there as the possible cause
Hey Folks.
