04-23-2023 06:21 PM
I upgraded my modem/router. How do I reconnect my front/backyard cameras, indoor camera and nest doorbell?
04-23-2023 06:36 PM
Basically, you need to remove them from the Google Nest app or the Google Home app while on the old Wi-Fi network, do a factory reset, and then reinstall them while on the new Wi-Fi network:
04-28-2023 09:56 AM
Thanks for the explanation, MplsCustomer.
Hi Gayharrison,
I just wanted to jump in real fast to see if you saw MplsCustomer's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Jeff
05-01-2023 10:30 AM
Hey again Gayharrison,
I just wanted to follow up once more to see if you were still needing some help here. If so, just let us know.
Jeff
05-02-2023 02:33 PM
Jeff
05-02-2023 05:28 PM
I have not gotten the cameras back up and running. I am having trouble finding someone who can reach them. Do you know of a service I can call?
05-07-2023 07:00 PM
John397, fantastic! We're glad to hear that our support team was able to help you.
Gayharrison, could you try the steps shared above by John397? Keep us posted.
I appreciate the help here, MplsCustomer and Jeff!
05-04-2023 10:36 AM
I just spent a frustrating two days trying to reconnect my wired indoor camera to a new router. Once I was able to get a hold of Google support and speak to somebody it was a very easy process. Using the Google Home Ap, I selected add new device and selected my wired camera. Then had to reset my camera which meant that I lost all my video history, which was not a big problem. What nobody told me is how to reset the camera: with the camera plugged in, you insert a straightened paper clip in the small hole located between the camera head and the base. Push the button at the bottom gently and hold it FOR 12 SECONDS or until you hear a chime. Once you hear a chime, the white light will come on at the top of the camera above the lens. Keep holding the paper cup gently until the white light turns to a green light. At that point while you are using the Google Home app you should be able to choose the new Wi-Fi network and enter the password. Voila.
05-10-2023 07:18 PM
Hey Gayharrison,
It's me again. I want to check if you still need help. Don't hesitate to reach back if you do.
05-11-2023 07:43 PM
Juni
