Replacement cable
Eddiejenkins
I have a Nest Outdoor cam, not the Nest IQ Outdoor cam. The power cable is not weatherproof as the outer wire casing has degraded and the bare wires are showing, badly. Can the power cable be replaced? If so, how do I get a replacement cable? Also, the cable plugs into the back side of the camera and I have tugged on it and still am unable to detach the cable from the camera.
Thank you for your patience. If you are seeking a replacement, please first fill out this form so we can collect some important information from you. Once the form is submitted, you will have your case number. Please be aware that this thread will be locked.
