Loses connection when rung in cold weather
Mstoney
Does anybody else have issues that the doorbell loses connection when rung in cold weather? When the weather gets below like 45 degrees, it pretty consistently loses connection when someone comes to the door and never comes back online. This doesn’t happen in warmer weather. It’s exclusively when it’s cold. The only solution I have found is to go outside and disconnect all wires and reconnect everything again. Getting pretty fed up spending cold days outside fixing a doorbell.
Mully4478
Same issue although it is when it gets below freezing.  I have good Wi-Fi coverage where it is located, but it consistently disconnects when it is cold.  Per Google, it says it can operate in much colder conditions and I am getting tired of having to reconnect when it is 20 degrees.
Mully4478
I do need help as I haven’t gotten any resolution to the issue.
Hi folks.
We do not have a fix for this issue, we are still looking into it. Please refer to this Main Thread on this issue. In the meantime, this thread will be locked. Please refer to the original thread.
