Solar panels compatible with the G3AL9 outdoor nest camera?
TC-TT
Hi! I have Google Nest battery cameras that I have to take down and bring into the house to charge. I want to add solar panels so I don't have to do this anymore. The prongs on my cameras are 4 straight in a row. When I go to look at "compatible" solar panels the charging prongs are 4 curved not straight. Does anyone know if there are solar panels for the G3AL9 cameras with 4 prongs straight in a row on the charging wire?
Thank you for any help or advice,
TC
BeulaA
Hi @TC-TT,
Thanks for posting to the community! I understand you are looking for solar panels compatible with your Nest Cameras (battery) because you would like to keep them powered continuously and avoid manual charging. I’m happy to help!
For these specific cameras, you can find a compatible solar panel through the Google Store. I recommend the Wasserstein Solar Panel, which is specifically designed for Nest Cams (battery). You can find more details regarding the product here: Wasserstein Solar Panel For Google Nest Cam (outdoor or indoor, battery).
I hope this information helps.
Beula
