05-24-2022 08:58 AM
I just changed network provider and needed to reassign the wifi connection to my Nest Cams. I have three original Nest Cams the transferred to the new network fine. However the newer Nest Google products, outdoor battery powered cam fail at every attempt to add to my new network.
I get to the response when setting up:
Something went wrong
Try connecting again. If that doesn't work, try rebooting your device or turning your phone's airplane mode on and off before trying again.
I have done all of those recommend actions and pressed the reset button on the back of the camera to reset. But nothing works. Definitely not user friendly!!!
05-24-2022 04:14 PM
I have tried about ten times, changing things every time and no luck. Should I request a refund on these cameras?
06-02-2022 12:28 PM
I looked at other member that were having the same issue and found a solution in their topic submission.
06-02-2022 01:52 PM
I apologize for my late response and thank you for all of your patience while waiting for a reply. I understand how frustrating your situation must be, and I would love to help however I can. Do you still need assistance?
06-10-2022 09:19 AM
Just checking in to see if you still need assistance with this issue. We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments.
06-07-2022 09:12 AM
Did you have any more questions or need any additional help?
Thank you,
Jeran
