Unable to adjust settings for Floodlight
Dprewitt
I just finished installing 3 Nest Cams with floodlight. The first 2 work flawlessly. I'm unable to adjust any settings for the floodlight setting for the last Nest Cam with floodlight. When I select floodlight in the settings on the Home app for the "Backyard" cam. It's states "Unable to Connect Rety". All other settings show up and I'm able to make changes. Live view works fine. I can manually turn on the floodlights, but unable to make changes like how long they stay on and sensitivity. I have turned off the power and back on. All 3 devices are on the correct network. All are hardwired power.
Dprewitt
Problem resolved. I removed the device and re-added it to the Home app/network. Everything works fine. Thanks for the assistance.
Dprewitt
