04-06-2024 10:54 AM
I migrated my account to Google and lost connection to my thermostat and doorbell. I was able to get back to the thermostat but I am trying to reconnect the doorbell. The factory reset steps (push the doorbell button and the pinhole button for 10 seconds) doesn’t reset it. The app keeps telling me that the device is attached to another account. Any ideas?
04-06-2024 02:47 PM
Perhaps you should contact Support. We migrated in 2020, but migrating from a Nest Account to a Google Account should not cause you to lose "connection" to your 1st gen Google Nest Hello Doorbell. You should be able to log into the Google Nest app using the "Sign on with Google" option and all of your Google Nest devices should be there.
04-06-2024 01:32 PM
I am having the same problems. I have wasted two afternoons (7+ hours) Connecting and reconnecting wires, migrating (again) my Nest account to Google. I have pushed the pinhole factory restart, reset, I have pushed both the reset buttons and the doorbell simultaneously. This should have been much easier.
04-06-2024 02:47 PM
04-10-2024 04:42 PM
Thank you for the advice! Google Support was amazing! My issue ended up being the doorbell was connected to a different account but they stayed with me while I reset it and reconnected and configured it. I am impressed with their service!
