11-05-2024 01:27 AM
On my google nest doorbell wired the factory reset doesn't work. It does come with the yellow ring and then the blue but does not give an acoustic signal. It also starts up again, but no acoustic signal. Can't add it to Nest app either.
11-10-2024 01:00 PM
Hi @Terrag,
Thanks for posting here in the community. I'm sorry to hear your Nest Doorbell is not resetting properly. I'm happy to help!
To better understand the situation, I'd like to ask a few questions:
In the meantime, let's check a few things:
Keep me posted.
Melany
11-11-2024 02:43 AM
Thanks for your response,
This is a nest doorbell 1st generation.
Problems started when the camera went offline. Even after switching the power off and on,
the camera no longer came online. A normal reset didn't help either.
Then tried a factory reset, press the reset button and the call button together and then hold it for at least 10 seconds, as stated in the instructions.
When I do that, the call button flashes yellow twice and then turns off without a sound, the bell then starts up and the call button turns blue but again no sound is heard. If I then want to connect the bell via the nest app with the QR code, I do not get a connection error code nc023
When I try to connect the bell without the QR code, but with the serial number, etc., it does not find a bell either.
11-11-2024 01:25 PM
Hi there!
Thanks for the follow-up information.
Let's try the steps in this guide:
Let me know how it goes.
Melany
11-12-2024 04:20 AM
Thanks again for the reply
I have already tried the steps with two different smartphones and two different tablets.
Doesn't work with all of them.
I suspect that the factory reset failed, causing the Bluetooth not to work either
11-13-2024 04:36 PM
Hi there!
Thanks for the update.
The team would like to learn more about this behavior. When you get a chance, please fill out this form and let us know when you’re finished. We’ll have someone reach out to you via email from there.
To help us assist you better, please include the link to your Community thread and your Community username.
Keep me posted.
Melany
11-15-2024 05:12 PM
Hello again!
We haven’t seen your form submission come through - were you able to access it alright? Let us know if you’re running into trouble or still need our help!
Melany
11-16-2024 01:38 AM
Apologies for the late response. I have just completed the form.
Regards
