06-01-2024 10:05 AM
Hi. I have to floodlight camera. It just started saying offline and i cant get it to reconnect. The lights work and when I look throught activities I see it works and captures motion I cant see it on the home screen because it says offline
06-04-2024 11:24 AM
Hi @zoki,
Thanks for reaching out. I'm sorry to hear that you're having offline issues with your Nest camera with floodlight. Let's work together to get this resolved! To help with that, I have a few questions for you:
In the meantime, you can find some troubleshooting tips in this article: Fix Nest camera or doorbell Wi-Fi connection issues.
If you have any further information that might be relevant, please feel free to reply to this post.
Sincerely.
Jonathan
07-02-2024 01:19 PM
Hi, Zoki-
I have 2 floodlights that started showing this behavior the last 2 weeks (seems to coincide with the timing of the install issues others on the communities board are having). The Home app shows them offline, but they respond to network pings, send motion alerts, recognize faces, and I can watch the video that is recorded on the Home app. So they ARE online and working normally but they simply just show 'offline' in the app.
I found if I cut the light switch off that they are connected to and let them run on battery for about 5 minutes, they start showing on-line again. That process works with both cameras. No idea why that works, guessing bug in latest SW (that's happened several times over the years), something wrong on at the backend, or something up with the Home app--but that's just a wild guess.
Cameras are on SW ver 1.73.1.73c 416403
