need help installing the puck in my doorbell chime with 6 wires
rferg
I am having trouble figuring out which wires to attach the puck to.  I have 6 wires with two chimes and one doorbell.  The basement chime appears to be daisy-chained.  The chimes has two red wires attached to the trans terminal and two white wires together in a wire nut with one red wire and one white wire on the Front terminal.  One white wire in the wire nut and that red wire going to the trans terminal.  The second white wire in the wire nut has its red wire going to the front terminal.  Any advise on where to hook up the puck?
sicsacol
Hi @rferg,
Thanks for reaching out. I understand that you'd like some help installing the chime of your Nest Doorbell Wired. Don't worry, I'm here to help you. To better assist you, please confirm:
  • Is your Nest Doorbell Wired 1st or 2nd gen?
  • Please share a picture of the wiring of your chime puck.
  • Share a picture of the wiring of your transformer.
Any additional details you can provide will be helpful.
Jonathan
