01-29-2022 03:14 PM
Using a nest cam battery, how can remove the base ring from the mount? It seems the magnet holds it so tight I can't turn it to get to the screws so I can relocate it.
02-04-2022 01:07 PM
04-22-2022 02:33 PM
We hope you were able to get the help you need but if the issue persists feel free to create a new thread, and provide as many details as possible so that others can lend a hand.
James
