nest camera compatibility with surface pro
LittleCreek
I have a new outdoor cam.   We set it up on my wife's ipad and we see it fine on her device.  However, I have a surface pro and am unable to view the camera.  I downloaded Bluestacks but cannot find google home on it  Is there a fix for this problem?
@LittleCreek
Unfortunately, Google Nest chose not to make its new cameras and doorbells work with the existing home.nest.com website, but only in the Google Home app.
Some customers have posted here installing and using BlueStacks and then downloading an Android version of the Google Home app on their PC or Mac. I haven't done it and can't offer any advice on it, but here is BlueStack's page on the subject: https://www.bluestacks.com/apps/lifestyle/google-home-on-pc.html
aatienza
Hey LittleCreek,
Appreciate the help, MplsCustomer. I'm dropping by to ensure if everything is covered here. Hope that sheds some light on the issue.
Archie
aatienza
Hey LittleCreek,
Archie
aatienza
Hey LittleCreek,
Archie
LittleCreek
I did find an app (NOX) that does allow me to access the camera.  It is slow but does an adequate job.  You do have to load the 9th version for the app to work.   Thanks
