06-17-2022 02:46 AM
Hello ,recently I bought nest camera wired 2nd gen and very often it is offline. I mention that I even brought the camera to the factory settings but in vain. It works for a while after which it is again ... offline. Of course I disconnected the camera from the voltage, in vain. It stays offline. What am I wrong with? Of course it is not vb of the wifi signal, it is 1m away from the router (asus). Thanks
06-22-2022 05:17 PM
Hey EstoQuodEs1,
That certainly hasn’t been easy for you. Let’s check what’s going on. Did you make any changes to your Wi-Fi network? Do you have other Nest devices in the house? Also, are there devices or appliances (such as baby monitors, microwaves, cordless phones, etc.) near the camera?
Archie
06-25-2022 05:41 AM
Hello,come back with news. After many disconnections (tired of restarting the router) I started looking through the mobile application of the Asus router. protocol for wifi 6 and so far I have not had any problems. It remains to be seen how the situation evolves.
06-27-2022 08:19 PM
Hey EstoQuodEs1,
Thanks for the update. Keep monitoring it and let us know how it goes.
Archie
06-30-2022 08:55 PM
Hey EstoQuodEs1,
Archie
07-04-2022 11:11 PM
Hey EstoQuodEs1,
Archie
07-04-2022 11:46 PM
Hi,1 week works flawless,and ....no more.Keep disconnected after few hours of working.Restarting my router....work 1 hour ....offline.Dont know what to do ..
07-06-2022 11:20 PM
Hey EstoQuodEs1,
Understood. Could you tell us the status light of your Nest Cam Indoor? Also, what Wi-Fi frequency band do you try to connect to (2.4 GHz or 5 GHz)?
Archie
07-06-2022 11:22 PM
Green led status, connected on 2.4Ghz
07-07-2022 10:05 PM
Hey EstoQuodEs1,
Got it. Try connecting your camera to 5 Ghz to see if that helps. Also, try to restart your camera to refresh the connection. If that doesn't work, try to reset it to its default settings. Here's the link on how to do it. Also, if you want to save any video footage before you perform the factory reset, create video clips or timelapses and download the files to your phone or computer. Keep us posted.
Archie
07-07-2022 10:10 PM
Hi,already try all above.Nothing ,camera will work couple of hours and then again goes offline.Im reverting router settings back to smart connect (combination of 2.5 and 5 GHz) and wifi 6 enable because in the end it's no difference,camera will go offline
07-13-2022 03:53 PM
Hey EstoQuodEs1,
Thanks for trying those steps. Could you fill out this form and let us know once you're done?
Archie
07-19-2022 06:21 PM
Hey EstoQuodEs1,
Archie
07-20-2022 02:31 AM
Hi, thanks for your support.Still keep my camera under observation.
07-20-2022 08:02 AM
Just checking in on this thread and the activity on it. We'll leave this topic open for another 24 hours in case there are any follow up questions or comments.
