nest camera with floodlight wired
Nike4362258
hi i got the cam installed by a electrician    went through the step sequences got to the pont turn   power back on at the circuit breaker wont allow me to move forward just recycles back through the set up steps again
6 REPLIES 6
I apologize for my late response and thank you for all of your patience while waiting for a reply. I definitely understand how frustrating your situation must be, and I wanted to make sure that your concern was acknowledged. Do you still need help with this issue?
SteveT1
Just wanted to check and make sure that you’ve seen our response. If you have other questions and concerns, feel free to let me know.
Steve
Just checking in to see if you still need assistance with this issue.  We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
Nike4362258
i got to work finally,but i was told the Nest camera with floodlight is not compatible with the Dish Hopper only the 1st Generation are is this true?
@Nike4362258
I honestly do not know what dish hopper is, so I do not know how to answer this question. My assumption is that if you have heard it is not compatible, it is most likely not compatible. I apologize if this is unhelpful, but I do not know anything about Dish Hopper.
-Brad
SteveT1
Do you have any more questions or need any additional help? If not, I'll go ahead and lock up this thread in 24 hours.
Steve
