10-28-2023 07:03 PM
Seems that one of three cameras turn off on its own. Exceedingly difficult to turn it back on. Thoughts/help? Can't find anything on google sites to address the issue.
10-29-2023 11:34 AM
The newer cameras seem to have more problems than the nest predecessors. I’ve had 2 of the cameras go bad without any solution from Google support except to tell me my cameras are out of warranty. 💵 gets expensive after spending money on cameras and they’re aware service.
10-31-2023 03:37 PM
Hello everyone,
@krbugler, i understand that you're having trouble keeping one on your Nest camera to stay on. I'll be happy to look into this. Just to check: What type of Nest camera are you using? If it’s wired, have you tried using a different power outlet or a different USB cable? If it's a battery-type Nest camera, have you tried charging it for more than 5 hours or tried doing a factory reset? Here is a link on how to restart or factory reset Nest camera
@canosoup, i’m sorry if you have to go through this. Can you please share the Case id when you contact our phone support?
Edmond
