power adaptor
kenny5
hi
uk user here. i want a plug in power adapter to keep door bell on a constant feed. can anyone recommend one that will does this. i have a plug socket near the bell.
many thanks in advance
@kenny5
Google Nest sells this power adapter that will work with the battery doorbell:
https://store.google.com/product/ninety7_indoor_power_adapter_nest_hello?hl=en-US
However, even when the battery doorbell is connected to power, it still runs off of battery power: "If you’ve connected your Nest Doorbell (battery) to your existing doorbell wiring, the wires don’t directly power the doorbell. Instead, the battery is trickle charged by the power that comes through the wires, and the doorbell runs off the battery charge." https://support.google.com/googlenest/answer/11830989
And because of that, the battery doorbell cannot record 24/7: "24/7 video history is not available for the Nest Doorbell (battery), even with optional wired installation." https://support.google.com/googlenest/answer/9681538
thank you
janthadeus
Hi kenny5,
I'm dropping by to ensure that everything is covered here. If you have other questions and concerns, feel free to let me know.
EmersonB
Hey everyone,
@kenny5, we wanted to follow up and see if you are still in need of any help. Please let us know if you are still having any concerns or questions from here, as we would be happy to take a closer look and assist you further.
I appreciate the help, JT and MplsCustomer.
janthadeus
Thanks for chiming in, Emerson.
