Cable replacement
Brujoadr
Hello there,
My dog cut the cable usb-to-usbc. I buy a new one (9v/2.4A) and dont liked, tried another cable from my mobile but same result. So, where i can buy the original cable?.
Bye (sorry, i tried my best to write in english)
Brujo
7 REPLIES 7
RXShorty
Hi @Brujoadr
According to the support page: 5Volt and 1.5 Amp, a good quality cable should do the trick.
As far as I am aware, there is no option to buy a separate cable, only a Power adapter with an Ethernet option (which also powers the device). 😊
Brujoadr
I tried two different capable cables and nothing happend. I check google store, if i buy this power adapter, can i use without ethernet cable? it works?
Hi @Brujoadr
Yes, it works just fine without the ethernet cable. You are still able to use the built-in WiFi. 🙂
Brujoadr
Thanks @RXShorty for your time and patience.
Jeran
Hey there Brujoadr,
I'm just checking up on this thread, I'm glad to see that RXShorty was able to answer your questions! In that case, do you have any more questions or need any additional help?
Thank you for helping out on this thread, RXShorty!
Jeran
Brujoadr
Hi Jeran,
Nop, that's all.
JenniferV
Hi Brujoadr,
Got it. Since you don't have any more questions and concerns, we'll go ahead and lock this thread now. Feel free to create a new one should you need help in the future. Have a good one!
Thanks for the help here, RXShorty and Jeran.
Jennifer
