01-19-2023 05:53 PM
I just updated to Android 12. Unfortunately, I can’t reconnect my usb c hub back with my thumb drive. Whenever I seem to reconnect the hub it seems as though my it requires more power than before. Why is this? How come it didn’t happen before? Also why doesn’t a device like this have more storage and memory for all of my streaming apps?
01-31-2023 09:28 AM
Hey there SogyBanjotime99,
I apologize for the late response, and thank you for being patient! Were you able to fix that USB hub issue? If not, I'd be happy to help you out. What kind of USB hub are you using? According to this article, to expand your Chromecast’s storage, you’ll need a:
I look forward to your response, and if you have any other questions or concerns for me, please let me know.
Jeran
02-03-2023 09:48 AM
Do you have any more questions that I can address?
Thank you,
Jeran
02-03-2023 01:37 PM
I have a 30w anker power supply and usb c hub to a usb-2 flash drive. It use to work.
02-15-2023 01:01 PM
There was a recent update to the Chromecast with Google TV's firmware. Would you be able to update your Chromecast and try using that power supply again?
Jeran
02-23-2023 04:36 PM
Currently using the provided power supply and there is no update available.
02-20-2023 08:34 AM
Were you able to check for that new Chromecast with Google TV update?
Thank you,
Jeran
02-21-2023 12:06 PM
Hey SogyBanjotime99,
Do you have any more questions? If not, I'll go ahead and lock up this thread in 24 hours.
Just checking up,
Jeran
02-24-2023 01:06 PM
What do you suggest if it is showing that there is no update available?
02-27-2023 11:29 AM
Any updates, suggestions, or communication around this issue?
02-28-2023 10:17 AM
The Chromecast with Google TV firmware update should have been rolled out by now. In this case, it may be better to speak with Chromecast Support, as they would have more tools to look deeper into this issue. If you don't mind, would you be able to fill out this form to have them reach out to you via email?
Jeran
03-03-2023 10:26 AM
Did you have a chance to fill out that form I provided?
Thank you,
Jeran
03-06-2023 01:23 PM
Thank you for filling out that form! You should have someone from Chromecast Support reach out to your e-mail in a few days, so keep an eye out. In the meantime, unless you have any further questions for me, I'll go ahead and lock the thread in 24 hours.
Jeran
