10-29-2022 01:25 AM
I HAVE PROBLEM ON THIS ANDROID 12 , I'M CURRENTLY USING MY USB HUB TYPE C ON MY CHROMECAST 4K , BUT I DECIDED UPDATE IT ON ANDROID 12 IT CAN'T READ MY FLASH DRIVE ON MY USB HUB TYPE C
11-07-2022 09:34 AM
Hey there tvlangs24,
I apologize for the late response, thank you for being patient! Were you able to fix that flash drive issue? If not, I'd be happy to help you out, since this issue sounds pretty frustrating. First, I would double-check to see if there are any more updates for your Chromecast. Then, I would unplug the USB Hub and connect it to another device, to make sure it's still working. Then, I would restart the Chromecast, and plug the USB Hub back in and see if the Chromecast can detect it.
Jeran
11-10-2022 09:52 AM
Do you have any more questions or need any additional help?
Thank you,
Jeran
11-11-2022 10:19 AM
Hey tvlangs24,
Do you have any more questions that we can address? If not, I'll go ahead and lock up this thread in 24 hours.
Just checking up,
Jeran
