02-07-2023 06:00 PM - edited 02-07-2023 06:01 PM
I've struggled with this for a while.
Has anyone found a more convenient way to connect smart devices that work on only 2.4 GHz to Nest WiFi Pro mesh setup?
It's like jumping through hoops at this point. I've used old phones with only 2.4 capabilities, and have walked away from my home until the bandwidth is forced into 2.4. This seems ridiculous in my opinion. I'm about to just plug in a separate router with a hidden SSID just for smart devices.
Turns out the latest and greatest WiFi forgot smart devices, unless anyone has an easy workaround they would like to share.
I'd love to see a 'set up smart device mode' in the google home app that forces only 2.4 for a while.
02-18-2023 07:37 AM
Google Wifi and Nest Wifi don't have a feature to enable separate network names for the 2.4 GHz and 5 GHz bands. Some smart home devices are only capable of using the 2.4 GHz band and will not be available for setup if the phone or tablet you're using for setup connects to the 5 GHz band. Here are some potential solutions:
Hopefully one of these solutions helps!
02-20-2023 10:36 AM
You've been awesome providing those helpful steps, davidking!
Ntg, checking back in if the steps suggested above by our Product Expert helps. Let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
Alex
02-23-2023 12:06 PM
Hi Ntg,
It's me again. I don't want to be a nudge but I'd like to check if you still need help with your Nest Wifi Pro? Let me know by updating this thread so that we can help.
Alex
02-26-2023 02:34 PM
Hello there,
We want to ensure you are good to go, and everything is working properly. Please let us know if you are still having trouble, as we will be locking the thread in 24 hours due to inactivity.
Alex
